All my studs on the wheels have the beginning 3/8 inch worn by rust as have each lugnut, so their integrity is very poor. Especially since not much of the stud extends beyond the wheel to begin with, and several of the lug nuts have no purchase at all, so they won't even stay on. My question first off is, "what is the thread size of these studs, and how difficult are they to punch out and replace"? I see new ones are available. I would hate to take a hammer to the old stud to knock it out only to break the wheel hub.
Does anyone have any knowledge of this situation?
  • 3 months later...
Okay, heated the studs and got them knocked out. Problem now is the new studs are so tight I've already stripped one of the stud nuts. So, now I have to take off the axle nut and take the whole disc and brake off. Question is, is the axle nut left hand thread or right hand thread? clockwise or counterclockwise? And heat hasn't worked on that so far. I may have to split it to get it off, but would be good to know which way to try and remove it
Thanks, got the axel nut and hub off with LP torch and breaker bar with 4 foot extension. Now, I can't get the bolts out of the brake disc. Torx head, which is good, I have that, but so far heat won't loosen them.
Got her done. I filed the edges of the disc bolts so I could get a vice grip on them, then a little heat and they came out slick. Then I was able to pound the studs in. Man, they are tight. Got it all back together and ready to ride.
By the way, the axle nut is a 30mm or 1 3/16.
Thanks for everyone's help.
Edited by data89
    • By TomJulio
    • By geezer99
      Well, I bought the Axis 500 sold at Lowes for $8999 a couple days ago.  This post will be about my impressions as I use, fix, and abuse the machine.  I will add to the post as I gain experience with it.
      Thanks to other posters on this site warning of new machines with loose hardware, one of my first actions was to crawl all over it checking fluids and connections.  Zirks were all freshly greased, fluids in engine, and gear boxes were up to level.  One of the little gas struts that help lift the bed to dump was dangling with only one end connected, and the other strut had not been fully tightened.
      The rear gearbox does not have a differential in it.  It is essentially a solid axle.  Tight turns on lawn will leave tracks, and turns are not as tight on pavement.  In my case this won't matter much, but if you plan to use it on a lawn, this will create tracks on turns.
      To check engine oil you need to remove both front seats and a plastic cover.  This according to the manual.  I'm pretty sure it can be checked with that stuff in place, either from under or above, but that remains to be seen.
      I am not used to a CVT transmission.  I am used to a clutch and multiple gears.  This one requires giving it plenty of gas out of the hole and then backing off to get it to shift up.  I'm sure I will get used to it, but I'd like to be able to take off quietly if I want to.
      The doors have bungie cords to act as springs to close them.  I removed the driver door so I would not need to fight the constant pressure to close.  Problem solved.  I will leave the passenger door as is.  Gotta keep the grandkids safe.
      Here is some stuff I like:
      I was concerned about there being enough torque to slowly climb a steep hill.  There is.  I will elaborate more on this when I've had it on my steeper trails.
      The display has dedicated lights to indicate status of gear position, low oil pressure, over temp, and a bunch of other stuff.  This helps a beginner with feedback that an action taken was successful.
      The sparsity of knobs on the tires dig in well on most surfaces.  I bet they wear out fast on pavement.
      The tilt bed has a tail gate that is easy to operate.  Much like early Japan pickups.
      Steering is responsive and little slack.  Remains to be seen how long to get loose since the u-joints are operating at quite sharp angles.
      Seats are pretty nice.  Will be interesting to see how long it will take me to poke a screw driver though them.
      Seat belts are included to hold grand kids in.  Won't go over 5 mph if both aren't buckled.  Yeah, it works to buckle them empty.  Doing this leaves the belt high on back, so you don't have to sit on it.
      Hauling it home, my trailer wheel wells were too close together to clear the tires of the UTV.  This required driving it off center a bit, with one set of tires inside the wells and one side driving over the wheel well.  Creeping over the one well required climbing a 10 inch vertical well.  The ability to lock the front axle differential kept both front wheels pulling as I drove the one side up and over the wheel well.  The guys at Lowes were impressed.  They won't touch any but an unobstructed flat trailer loading.
      tom
    • By TomJulio
    • By treycotiii
      Looking for the best options. I primarily use the machine for snow removal and yard cart pulling.
    • By sunn
      Anyone with experience on relocating the miniscule battery from the front lower center wheel area to the left rear wheel area on the Polaris Sportsman 570?
