MAX 4 6X6 2008
quad is a new to me freebie, pulled carb and cleaned it. got it running and idling nice but mid throttle it craps out and will go down to almost a stall, i release throttle and it just sits there idling away happy as a pig in poop. i was thinking fuel restriction then i noticed the exhaust glowing red in the sunlight. so its running lean
bottom of the tail pipe was rusted out and the little nut also ripped off when i tried to undo it.
a 540 ml soup can is the same id as the exhaust pipe od and the soup can has ridges to make it a tight fit
a little bit of a mickey mouse fix but it works
Hi! The wife and I are planning to head to Indian River this fall for a couple days to ride the ATV trails. Looking for a good place to stay that is close to the trails so we can ride from the lodging location. Any recommendations or tips on Indian River? Thanks a million!
