I need to replace the u-joints on the front driveshaft. I am having trouble getting the axles out to remove the differential. Might need advice on removing the driveshaft as well.
    • By WeeBee
    • By TomJulio
    • By jen
      Cannot find out why 12 vdc  4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm.   When attempting to run  with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic.  I can buy a rebuild kit ~$35 but WTH?
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
