Guest jstemple
Sometimes gas will drip to almost steady flow out of the port in the bottom of the carb bowl. Ive taken the carb apart and bent the float, but still, from time to time, gas pours or just drips out. Any ideas?
Guest jstemple
It was, I replaced the float needle and that didnt cure it, so I used a q-tip to clean the seat where the needle closes against and that did the trick.
Ethanol!
Shut the fuel off and let the carb run dry when done riding. That should help.
I (and alot of others) are switching to non ethanol gas because of this problem.
    • By mehim
    • By Travis_Smith
    • By DPDISXR4Ti
      Thanks...
    • By Topendcol
      First issue was fuel pump wont start once ignition has been turned on. Replaced the pump as I had one on hand, than noticed no power so replaced the fuel pump relay as that was were i traced the power to. Still nothing so further inspection looks like signal is coming from the PCM (FLR B20) but not switching the the brown wire to the fuel pump. Ive checked the operation of the bank angle sensor and it appears operational. Fuses and wiring all appear OK. The engine stop relay also tests OK. Ive been through the repair manual and diagrams but to no avail. Fully stumped, any tips would be helpful. Thanks
      Col
    • By Ryan Menard
      I have the strange issue where the float bowl drain screw on our ‘16 outlaw 50 is leaking by and letting fuel drain out of the tube.  It is not the overflow tube.  I have taken the carb apart to clean as well as taken the screw out and reinserted it but it still leaks by.  I can’t seem to find the screw alone for sale, all I can find is the whole float bowl for $100.  I would rather try a new screw first.
      Does anyone know what screw will work in the factory carburetor and/or where to purchase one from?
      Thanks.
