The Ozark and Recon pretty much are evenly matched in Horsepower and torque. The Recon turns tighter and is a lot less tippier than the Ozark. The Recon has more room for the rider than the Ozark. The Recon is very cold blooded machine to start. The Ozark is not to bad for cooler to cold weather starting. The Ozark handles my 910 lbs yard roller better than the Recon.
I would highly recomend either machine to anyone considering either of these machines.The only reason I would buy a Recon over the Ozark , is because my Suzuki dealer SUCKS!
    • By cavry
      Cavry
    • By DexKing
      I recently got my hands on a free 2004 Recon that the owner had zero information on the machine or the history. Long story short, a little troubleshooting and research revealed i needed to replace the timing chain for it to stay running. when i opened the case, it the chain was so horribly stretched, that the tensioner pivot arm had play between it and the chain! I also found the oil pump chain totally disconnected from the sprocket due to being completely worn out. I tore the whole engine down and rebuilt it from the bottom up finding little things here and there that needed to be replaced. Upon inspecting the top end, i didn't find any bad/excessive play in the crank, rod bearings or wrist pin. Now the machine runs great, but even after 2x adjusting the valves, the chatter is way more than you'd expect from a honda normally. My neighbor is an auto mechanic by trade, and i asked him to take a listen. the look on his face when i started it and it was chattering like that was priceless! He mentioned that maybe the valves themselves might be wore out or stretched. my question here: what all can cause the excessive rattle up in the valve cover aside from valves being out of spec? Everything else seemed to be in decent condition as far as rockers and guides go. I am fairly new to small engine/ATV repairs, but am learning as a hobby and have a fair amount of knowledge with how to do some wrenching. Thanks!
    • By alexwv1863
      I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
      So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
      I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
      I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
