needing a lottba help, ive got a 98 big bear 350 motor was rebuilt 6 months ago, by someone i dont know it will not rev past 14 throttle, will not pull itself, valves are good, carb is good, timing is good, starts quick and easy, 120 psi with my compression tester, new plug, fresh battery, only thing that gets my thinking is that there is a lot of pressure coming in and out with stroke out of the crankcase breather on top of the head. any insight would be greatly appreciated as i am at my witts end
    • By Elk
      2002 Polaris Magnum 325
    • By Damien911
      Setting the timing on a 2005 Yamaha 250 Bruin
    • By BillR94
      Thank you for your time
      Bill
    • By 97kingquad
    • By maikytech
      Has 60 psi and motor recent flooded...what the true compretion
