Hello all,
I am still a little green when it comes to Atvs so please be gentle.
I was charging my battery to take the machine out for a test spin I thought I put it on a trickle charge and ended up putting it on a fast charge! Came back out to the garage to find it smoking not to bad with still I could see it steaming coming out the top. I looked and saw a little water on the bottom where the battery was sitting. I took the battery off the charger fast and let it cool down.
Question is did I wreck this battery it looks the same, the water and stuff is still inside? Do I just buy a new one or could or should I even try to charge this one again?
Thanks in advance
Monster
:unsure:
    • By tflack500tbx
      Background,
      Any Ideas?
    • By tds7
    • By hunky
      Thanks for looking!
