My 2005 Arctic Cat 500 started leaking fuel from the top right hand side of the carb. It looks and feels that the fuel is coming from under the throttle cable housing area just above the primer pump. I have not had time to take carb off. Has anyone had a leak on this side and area of their carb?
    • By Elk
      2002 Polaris Magnum 325
    • By tepin
    • By Shorty51
    • By sandman001
