Raptor 250 won't start
By joshua91673
first post
josh ohio
By Gwbarm
By Werewolf
By Scoopeddad
I have a 1994 big bear and I am starting to have issues starting. I put in a new starter and selnoid as the at stopped starting with the electrical but will still start with the pull cord. Where and what now should I be looking at to check? If I turn key to on and the switch to on then hit the start button, the bike clicks and then nothing. Lights still work but no response to the starter. Stumped now. Any help would be greAt.
By Andyjack
Hi everyone new to this forum, i just got a LT80 for kids to learn on but can’t get it started. There is a spark but not very good so changed coil but got one with separate cdi so wouldn’t work cleaned car but still no joy. Fuel is getting in as plug is always wet. Im baffled. Like i say there is a spark i was thinking timing might of slipped so going to try that. any help please really appreciate it.
