Ground on 1999 Suzuki Quad King 300
By docdoug72
Has anyone had a suzuki 230 quad lock the engine up? Its a well maintained bike, it locked up when my son was riding it. Pulled the plug, it has connected with the piston. I'm thinking the con rod let go. I don't have a service manual. Does the engine need to come out to check further?
By Suzukiquad
By Thekevinjb
thanks
By Atomusthenes
By Memphis
Regards
