Where is the ground wire terminated on a 1999 Suzuki Quad King 300?  I have the cowl off and battery cover.  The main 20A fuse keeps blowing.  I want to make sure the ground wire is secured.  I can't find it past the cowl.  Can anyone help with direction or a picture?  Do i have to remove the front rack and plastics?
All  I  can suggest  is to trace the   ground wire  back, as well  as the   positive wire between  the fuse and alternator (stator) the  short  could be  on either side of the circuit,  but  most likely  on the  positive side. If  a  fuse is blowing  power is flowing from  battery  on  positive  side..  Negative side is normally connected directly   to  ground
    • By noticon75
    • By jay41198
    • By LMI
