  • 10 months later...
    • By exalrod
      Hello All !
      I am looking for a service manual and wiring diagram for a 2005 50cc Polaris Predator 4 wheeler.
      Could anyone help with this?
    • By McG75
    • By ggreen
      Sorry if this is in the wrong section,I didn't really consider it technical or needing advice. 2006,Linhai 300cc.What I was hoping was to find someone with the starter idler gear pin length and diameter. I've had the cover off alot of times and never realised there should be a pin from the case that meets the cover holding the starter gear in place. Now,a deepwell 1/4 in drive,5/16 deep well sits in the pin holes perfectly. Should I cut a lock ring groove in the end of it like a factory pin? I was thinking of just tack welding a washer to the end?
    • By Tjp5093
      I'm working on my 02 Honda forman 400 and I have the side case off. I'm trying to see a picture of how the clutch fork and clutch arm on the end of the shifter shaft line up and what direction to face the triangle bearing with the spring.TIA!!!
    • By Fiend_138
      Just picked up a 2014(?) Chinese quad for my kids to play around on. I can get the quad to start up, but then it dies out when we get ready to take off. Do I just keep playing with the carb, or is there something else I should be looking at?
      Also, what kind of amps should I be looking for in a replacement battery?
