    • By BillR94
      Thank you for your time
      Bill
    • By HHurks
      Hi to all
      Newbie here. Not new to ATVs. Look forward to learning a few new things and hope to maybe help some too.
    • By McClaw
      Hi Guys, I'm new to this forum.
      I have been riding quads for the last 20 years, however my quads are extremely old and outdated, all three are about 20 years old LOL.
      I have been looking at upgrading, but need your input.
      I've narrowed it down to the Polaris Sportsman XP 1000 S or the Honda FourTrax Foreman 4x4 EPS
      What do you guys think?
    • Guest Fox300exchic
      By Guest Fox300exchic
      Here's mine...
    • By wjmedic
      Recently rebuilt front end on this Polaris 400. New axles, bearings, seals, control arm bushings, Hilliard clutch thoroughly cleaned and inspected with no damage noted.
      Everything put back to together. Placed bike on jack stands all four wheels off the ground, started in 2 WD switched to AWD both front tires spinning, when AWD turned
      off right front wheel will not disengage from AWD. Checked voltage at connectors both left and right connectors have no voltage with AWD switch off, and both have 12.4V
      when AWD switch is turned on. Repeated turning switch on and off several times with no change in condition. I am thinking this must be something mechanical with the
      Hilliard clutch on the right hub ie. weak spring or stuck rollers on the Hilliard clutch assembly (Is this a logical thought?) any ideas on trouble shooting this before I disassemble the
      right front hub again
