So just a few weeks ago I bought a 2008 arctic cat 366. The air intake was FULL of dirt so the rings went on it. It was definitely swamped. I tried honing it but there is still a groove going horizontally where you can feel a bump in it, possibly an indent. So I need to bore it out, anyone know a place near Langley I can go to? I also have no clue where to get my new piston and rings from since I will need larger ones, as well as the size of the new piston. I appreciate the help!
I'm not from the area, but I would search for a local machine shop that does work for the repair garages in your or neighboring town. Talk to them to see if they will do it and if you can supply the parts, which you can order online.
* Moved topic to Yamaha ATV forum and added ATV info into topic title.
    • By tepin
    • By marlon smith
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
    • By spigmef
      I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
    • By johnboer
      I've been tryna find a replacement intake manifold for my 85 LT250EF because it's all hardened up but i can't seem to find one. Are there any other manifolds that would fit this model. Or how should i soften this manifold. I saw that wintergreen oil would help to soften it up but i wouldn't know how long it would last. Any other tips on how to get a tight seal around the engine intake would be appreciated.
