2018 Can-Am MAVERICK X3 Video
By bradleyheathhays
Unfortunately it looks like I have some people in my new neighborhood paying a little too much attention to my auto and for the first time I'm feeling a need to add some security system(s) to old yeller. I think just a basic remote arm system would do, not interested at all in remote start or unlock. I'm not familiar with modern alarm systems, but here's what I 'think' I need...
- Door switches for all 5 doors (rear hatch). Probably a PITA to install but that's only an initial idea.
- 'Bump' alarm (not sure what it would be called) for if a window breaks or if something is jarred
- Geo-location function like a low track or something similar
Additionally I'd like to install possibly 2 start kill switches. I'm not sure where inline these are normally installed but my impression is that directly in line with the key ignition switch would be common. But then what if someone jumps the starter with a screwdriver...would this type of switch work in that instance? So that leads me to the idea of a second ignition kill switch which would either be wired between the battery and starter motor, or between the starter motor and ground.
And last...security lugs.
So am I over thinking this here? What's your recommendation for what I really need and maybe a good but economic alarm system that can get this done?
By Atomusthenes
By geekmonster
I need a service manual for a 2001 lakota sport im having issues with my oil pump getting jammed
By JORDAN6475
Hey everyone I'm hoping someone can help a guy out here!
I recently bought an Apache rlx400cc for pennies iknow it's Chinese but I thought it could do with a new life with such low mileage on it.
I serviced it and went to start it up to find the starter motor just spins? Is this a simple fix everything seems okay it has enough power to start the engine so not sure why it won't start however these bikes do have a pull start so it started straight away but after starting it a few times it started to slip when pulling I took the case of to find the teeth where broken on the receiver side the pawls are fine but I can't find a replacement anywhere as a matter of fact I can't even find out what it's called so I'm stuck!
If anyone can tell me what this is called please share with me.
By jatho
Does anyone know what year they stopped producing the King Quad 300? - particularly in Australia and New Zealand
What were the design changes?
