I have a 2003 Honda 400ex rejetted it last winter, put a slip on pipe nothing special but after a few weekends of riding it I lost my top end the bike starts and drives but when I give it throttle it bogs way out not sure what to do anyone have any suggestions?? Thanks in advance!!!
My  first guess would be  a faulty  accelerator  pump  (hole in diaphragm ?) but  also  look  for  an  air leak, or lean  run  from a  partially plugged  jet.  Try  adjusting the  air bleed  screw.  It  may  have turned out  on its  own.
    • By umax33
      i just got a 1986 honda trx 200 and the reverse and neutral lights don't work, i looked in the service manual and it says to remove two screws and the cover comes up and you can check the bulbs, the book does not show the two screws and i can't see them.Does anyone know how to get to the screws to check the bulbs. i will appreciate any help i can get...thank you
    • By docdoug72
    • By Atomusthenes
    • By Trent Finnessey
