On 6/8/2022 at 1:42 AM, Mech said:
For those interested, or having trouble with those sites.. Here's the suzuki specific criteria.. most of which is applicable to all makes though..
It has one mistake in it.. At one point in the explanation it says the check digit applies to the digits before the check digit, that's not right. The check digit checks all the digits, including the check digit..
The Vehicle Identification Number (VIN) is composed of 17 characters. The standard was originally defined in ISO Standard 3779 in February of 1977. Then it was revised in 1983. The ISO VIN is designed to identify motor vehicles of all kinds: cars, trucks, buses, motorcycles etc.
The Vehicle Identification Number (VIN) contains three major sections:
WMI - World Manufacturer Identifier (1,2,3 characters in VIN structure) If the manufacturer builds less than 500 vehicles per year than the third digit is "9". The WMI is described in detail in ISO 3780.
VDS - Vehicle Description Section. It contains 6 characters (4th to 9th positions in VIN) and defines vehicle attributes specified by manufacturer.
VIS - Vehicle Identifier Section. The last 8 characters of VIN define Year, manufacturer plant and serial (sequential) number of the vehicle.
The last four characters shall be numeric. The 10th position of the Vehicle Identification Number is a YEAR CODE.
ISO recommends that in VIN code capital letters A to Z and numbers 1 to 0 may be used, excluding I,O and Q in order to avoid mistakes of misread. No signs and spaces are allowed in Vehicle Identification Number code.
Recap with examples:
Digits 1,2,3 are World, Manufacturer, Identifier
Digits 4,5,6,7,8 are Vehicle descriptor Section -- *Somewhat variable based on manufacturer.
Digit 9 is the check digit
Digit 10 is the Year code
Digit 11 is the Factory code
Digits 12,13,14,15,16,17 are the Vehicle Identification Sequence
Let's see how this splits:
First digit - Country code
U.S.A.(1 or 4), Canada (2), Mexico (3), Japan (J), Korea (K), England (S), Germany (W), Italy (Z)
Second digit - Manufacturer
Audi (A), BMW (B), Buick (4), Cadillac (6), Chevrolet (1), Chrysler (C), Dodge (B), Ford (F), GM Canada (7), General Motors (G), Honda (H), Jaguar (A), Lincoln (L), Mercedes Benz (D), Mercury (M), Nissan (N), Oldsmobile (3), Pontiac (2 or 5), Plymouth (P), Saturn (8 ), Toyota (T), Volvo (V), Suzuki (S), Kawasaki (K).
Third digit - Identifier
Motorcycle (1), ATV (A) Kawasaki and Suzuki seem to follow this anyway
Fourth digit - Vehicle category
Data here is Suzuki specific, haven't found info for other brands.
ATV (A), Scooter (C), Business model or commuter (B), Single cylinder sport/street (N), Multiple cylinder sport/street (G), Family (F), Off road (S), V-Type engine, street, V2/V4/V6/8,... (V), Square Four (H)
Fifth digit - Engine Displacement
A=49cc and less
B=50-69cc
C=70-79cc
D=80-89cc
E=90-99cc
F=100-124cc
G=125-149cc
H=150-199cc
J=200-249cc
K=250-399cc
M=400-499cc
N=500-599cc
P=600-699cc
R=700-749cc
S=750-849cc
T=850-999cc
U=1000-1099cc
V=1100-1199cc
W=1200-1299cc
Y=1400-1499cc
Z=1500 & up
Sixth digit - Engine Type
1=2 stroke single
2=2 stroke twin
3=2 stroke triple or four
4=4 stroke single
5=4 stroke twin
6=?
7=4 stroke four
Seventh digit
Design sequence or model version first version uses 1 then second version uses 2 etc... the tenth version would then be identified by the letter A then B etc..
Eigth digit
First version uses 1 then second version uses 2 etc... the tenth version would then be identified by the letter A then B etc...
Ninth digit - Check digit
The ninth vehicle identification number digit is a VIN accuracy check digit, verifying the previous VIN numbers. This is how the check digit works
STEP 1
Assign to each number in the VIN its actual mathematical value and assign to each letter the value specified for it in the following chart:
ASSIGNED VALUES:
A=1 G=7 P=7 X=7
B=2 H=8 R=9 Y=8
C=3 J=1 S=2 Z=9
D=4 K=2 T=3
E=5 M=3 U=4
F=6 N=4 V=5
STEP 2
Multiply the assigned value for each character in the VIN by the position weight factor specified in the following chart:
VIN POSITION AND WEIGHT FACTOR:
1st = 8 10th = 9
2nd = 7 11th = 8
3rd = 6 12th = 7
4th = 5 13th = 6
5th = 4 14th = 5
6th = 3 15th = 4
7th = 2 16th = 3
8th = 10 17th = 2
9th = check digit
STEP 3
Add the products from steps 1 and 2 and divide the total by 11.
STEP 4
The numerical remainder is the check digit which would appear in the 9th position in the VIN. If the remainder is 10, then the letter "X" is used for the check digit.
Tenth digit - Year Code
80(A), 81(B), 82(C), 83(D), 84(E),
85(F), 86(G), 87(H), 88(J), 89(K),
90(L), 91(M), 92(N), 93(P), 94(R),
95(S), 96(T), 97(V), 98(W), 99(X),
00(Y), 01(1), 02(2), 03(3), 04(4),
05(5), 06(6), 07(7), 08(8 ), 09(9),10(A), 11(B), 12(C), etc.
Eleventh digit - Factory Code
Manufacturer code for what plant it was built in
Twelfth to Seventeenth digits - Serial Number
Your vin number will be on a steel plate welded to the left rear down tube I think.. real obvious..
This was so helpful and thourough, thank you. I was able to determine not just my year but all kinds of other info about it.
    • By bradleyheathhays
      Unfortunately it looks like I have some people in my new neighborhood paying a little too much attention to my auto and for the first time I'm feeling a need to add some security system(s) to old yeller.  I think just a basic remote arm system would do, not interested at all in remote start or unlock.  I'm not familiar with modern alarm systems, but here's what I 'think' I need...
      - Door switches for all 5 doors (rear hatch).  Probably a PITA to install but that's only an initial idea.
      - 'Bump' alarm (not sure what it would be called) for if a window breaks or if something is jarred
      - Geo-location function like a low track or something similar
      Additionally I'd like to install possibly 2 start kill switches.  I'm not sure where inline these are normally installed but my impression is that directly in line with the key ignition switch would be common.  But then what if someone jumps the starter with a screwdriver...would this type of switch work in that instance?  So that leads me to the idea of a second ignition kill switch which would either be wired between the battery and starter motor, or between the starter motor and ground.
      And last...security lugs.
      So am I over thinking this here?  What's your recommendation for what I really need and maybe a good but economic alarm system that can get this done?
    • By kevinohio
    • By buriedpast
