2018 Honda Teaser
By TomJulio
I recently noticed my Fourtrax 2WD has 4WD wheels installed on the front. The back spacing is significantly different than 2WD wheels and they are almost touching the strut springs and the tires actually do touch the springs.. So far, no luck locating 2WD wheels to correct this issue.
By treycotiii
Looking for the best options. I primarily use the machine for snow removal and yard cart pulling.
By Gwbarm
By kp3004x4
Curious to see anyone that has aftermarket tires,wheels .what size,how well made. Such as this. Welcome all community to chim in on what they have seen or have.
