Hi. I own a 2001 Yamaha Kodiak 400 4x4. I am looking to buy new rims for it. I just don't know what rims exactly that I need to get as the back and front rims have a different offset. I'm looking at the itp Delta rims. I have tires from my grizzly that I would like to use on my Kodiak. They are size 25. If anyone could help with the specific rims that I need to order, it would be greatly appreciated. Thanks
If  you   want  new  rims , all  you  need to  do  is  choose  the   brand  and style  you want  and tell the  dealer what they are to  fit .
If you  are looking at  used rims  you  need  to   know  the bolt  pattern  and the  offset  to  know  if you can  use them ..
Here  is a site that tells you  how  to  measure rims  to  find  the  specs on it ,  ans  even  handier   charts  showing  rim specs   for a whole range  of  quads  by  manufacturers ..  Look  up   your Kodiak   to  get  the   rim  specs , and then  compare them  to  other   makes  to  see  what  ones interchange.
http://www.mud-throwers.com/atv_wheel_chart
    • By wanrep
    • By wanrep
      YFZ05YYXH
      YF05RH
    • By Atomusthenes
