Carb Pilot Screw Adjustment
CACRWLR
 Share
Hi,
This might be a dumb question, but can you adjust the carburetor pilot screw on a '99 King Quad while the carb is on the atv?  There doesn't look like there's much clearance between the pilot screw and the cylinder head to get a screwdriver in there (if I'm looking at the right screw).  The engine runs pretty good; there's just a slight hesitation in the lower rpm ranges.
Thanks.
Dream Car Giveaway
  • 3 months later...
I'm in the same boat....they DO make a screw driver that accepts different bits that is on a flexible shaft, just like the idle speed screw that pushes the butterfly open via a cable that bends 90 degrees under the carb to the right side of the engine (at least it does on 2000 quadmaster 500)
 Share
  • Similar Topics
    • By BuddyLee
      Just started to bog in gear.  Chineses carb.  Taken apart and cleaned.  Starts good, runs good, throttles good sitting there but as soon as try to go it will bog.  Plug is black so I cleaned and adjusted needle downwards.  Kinda lost at this point…ideas?  Thanks in advance.
    • By GatorHunter
      Thank you, and enjoy
      GH
      1985 Scrambler
      1985 Trail Boss
      1986 Scrambler
      1986 Trail Boss
      1987 Trail Boss
      1987 Trail Boss 4X4
      1987 Cyclone
      1988 Trail Boss 2X4
      1988 Trail Boss 4X4
      1988 Trail Boss 250 R/ES
      1989 Trail Boss
      1989 Trail Boss 2X4
      1989 Trail Boss 4X4
      1989 Big Boss 4X6
      1990 Trail Blazer
      1990 Trail Boss 250
      1990 Trail Boss 2X4
      1990 Trail Boss 2X4 350L
      1990 Trail Boss 4X4
      1990 Trail Boss 4X4 350L
      1990 Big Boss 4X6
      1991 Trail Blazer
      1991 Trail Boss 250
      1991 Trail Boss 2X4
      1991 Trail Boss 2X4 350L
      1991 Trail Boss 4X4
      1991 Trail Boss 4X4 350L
      1991 Big Boss 4X6
      1991 Big Boss 6X6
      1992 Trail Blazer
      1992 Trail Boss 250
      1992 Trail Boss 2X4
      1992 Trail Boss 2X4 350L
      1992 Trail Boss 4X4
      1992 Trail Boss 4X4 350L
      1992 Big Boss 4X6
      1992 Big Boss 6X6
      1993 250 2X4
      1993 350 2X4
      1993 250 4X4
      1993 350 4X4
      1993 250 6X6
      1993 350 6X6
      1993 Trail Boss
      1993 Trail Blazer
      1993 Sportsman
      1994 300 2X4
      1994 400 2X4
      1994 300 4X4
      1994 400 4X4
      1994 300 6X6
      1994 400 6X6
      1994 Trail Boss 2W
      1994 Trail Blazer 2W
      1994 Sportsman 4X4
      1994 Sport
      1995 300 2X4
      1995 400 2X4
      1995 300 4X4
      1995 400 6X6
      1995 Trail Boss
      1995 Trail Blazer
      1995 Sportsman 4X4
      1995 Sport
      1995 Xplorer 4X4
      1995 Scrambler
      1995 Magnum 2x4
      1995 Madnum 4X4
      1996 Trail Blazer
      1996 Trail Boss
      1996 Xplorer 300
      1996 Xpress 300
      1996 Xplorer 400
      1996 Xpress 400
      1996 Sport
      1996 Scrambler 4X4
      1996 Sportsman 4X4
      1996 Sportsman 500
      1996 400 6X6
      1996 Magnum 2X4
      1996 Magnum 4X4
      1996 Magnum 6X6
      1997 Trail Blazer
      1997 Trail Boss
      1997 Xplorer 300
      1997 Xpress 300
      1997 Xplorer 400
      1997 Xpress 400
      1997 Xplorer 500
      1997 Sport 400
      1997 Scrambler 4X4
      1997 Scrambler 500
      1997 Sportsman 4X4
      1997 Sportsman 500
      1997 400 6X6
      1997 Magnum 2X4
      1997 Magnum 4X4
      1997 Magnum 6X6
      1998 Trail Blazer
      1998 Trail Boss
      1998 Xplorer 300
      1998 Xpress 300
      1998 Sport 400
      1998 Scrambler 400
      1998 Scrambler 500
      1998 Xplorer 400
      1998 Magnum 2X4
      1998 Magnum 4X4
      1998 Sportsman 500
      1998 Big Boss 500 6X6
      1996 Sportsman 400
      1996 Sportsman 500
      1996 Xplorer 500 4X4
      1997 Sportsman 400
      1997 Sportsman 500
      1997 Xplorer 500 4X4
      1998 Sportsman 400
      1998 Sportsman 500
      1998 Xplorer 500 4X4
      1999 Sportsman 400
      1999 Sportsman 500
      1999 Xplorer 500 4X4
      2000 Sportsman 400
      2000 Sportsman 500
      2000 Xplorer 500 4X4
      2001 Sportsman 400
      2001 Sportsman 500
      2001 Xplorer 500 4X4
      2002 Sportsman 400
      2002 Sportsman 500
      2002 Xplorer 500 4X4
      2003 Sportsman 400
      2003 Sportsman 500
      2003 Xplorer 500 4X4
      A01CH50AD
      A01CH50AA
      A01CH50AB
      A01CH50AE
      A01CH50AK
      A01CH50AF
      A01CH50AJ
      A01CH50EB
      A02CL50AA
      A02CL50DA
      A02CH50AA
      A02CH50AB
      A02CH50AE
      A02CH50AK
      A02CH50AC
      A02CH50AD
      A02CH50AJ
      A02CH50AL
      A02CH50AM
      A02CH50AN
      A02CH50FA
      A02CH50AAEB
      A02CH68AA
      A02CH68AB
      A02CH68AC
      A02CH68CA
      A02CH68CB
      A03CL50AA
      A03CH42AA
      A03CH42AB
      A03CH42AC
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03GJ50AA
      A03GJ50AB
      A04CL50AA
      A04CH42AA
      A04CH42AE
      A04CH42AG
      A04CH42AQ
      A04CH42AT
      A04CH42AV
      A04CH42AS
      A04CH42AR
      A04CH50AA
      A04CH50AC
      A04CH50AE
      A04CH50AG
      A04CH50AO
      A04CH50AQ
      A04CH50AR
      A04CH50AS
      A04CH50AT
      A04CH50AV
      A04CH50AW
      A04CH59AF
      A04CH59AH
      A04CH59AJ
      A04CH59AT
      A04CH59AV
      A04CH59AK
      A04CH59AL
      A04CH59AN
      A04CH59AW
      A04CH68AC
      A04CH68AF
      A04CH68AH
      A04CH68AJ
      A04CH68AT
      A04CH68AV
      A04CH68AK
      A04CH68AL
      A04CH68AN
      A04CH68AO
      A04CH68MB
      2004 Ranger 2X4 Parts Manual
      A04RB42AA
      2004 Ranger 4X4 Parts Manual
      A04RD50AA
      2004 Ranger 6X6 Parts Manual
      A04RF50AA
      A05CL50AA
      A05MH42AB
      A05MH42AG
      A05MH42AH
      A05MH50AB
      A05MH50AC
      A05MH50AG
      A05MH50AH
      A05MH50FB
      A05MH59AK
      A05MH59AN
      A05MH68AK
      A05MH68AN
      A05MH68AC
      A05MH68AS
      A05MH68AU
      A05MH68AW
      A05MH76AC
      A05MH76AU
      A05MH76AW
      A05MH68AP
      A07MH68MA
      R07RF68AD
      R07RF68AF
      R08RF68AD
      R08RF68AF
      2009 Outlaw 90 service manual
      Other Stuff
      Download Manuals HERE
      Some ATV manuals available in the downloads section at https://www.quadcrazy.com/files/
      Find them on on:
    • By Yammy
      Can you ride your quad on the road or cross a road if your quad is licensed and registered and you have functional signal lights and running lights?
      Let me know, I'm new to this.
      Thanks!
      Out on the trail, visibility is everything. When you’re riding, you need to be able to see every potential obstacle well in advance, and sometimes, that includes things behind or beside your vehicle. On your own private property, sideview and rearview mirrors are a clear value-add, helping you avoid some of the entirely preventable accidents that can pop up when you’re driving in Reverse. On public trails, those mirrors are an absolute necessity, drastically helping mitigate the risk of vehicle-to-vehicle collisions and prevent bodily injuries.
      That’s why Kemimoto, a market leader in the design and manufacture of ATV and UTV accessories, has devoted so much focus to UTV mirrors over the past decade, in addition to accessories like saddlebags, seat bags, whip lights, and more. When the company was founded back in 2011, there weren’t any readily available, affordable off-road mirrors for Side-by-Sides on the market that were much good for anything other than showing riders the rears of their own vehicles. So, the company’s founders took up the challenge, setting out to create their own side mirrors to provide fellow ORV enthusiasts with a better view of their blind spots.
      Mirrors have been Kemimoto’s hottest-selling products ever since.
      Today, Kemimoto has a staggeringly impressive collection of sideview and rearview mirrors for UTVs, ATVs, and bikes on offer, with nearly a hundred unique mirror packages on sale through the official Kemimoto website. Kemimoto makes mirrors to suit any need and any budget. Many of them are best-sellers in their respective categories, and for very good reason: as a direct-to-consumer brand, products are marketed, sold, and delivered to customers directly by Kemimoto. That extra efficiency allows the company to price its ATV and UTV accessories more effectively, and sell high-quality mirrors and other products while keeping prices extremely affordable.
      Equally important, Kemimoto’s ORV mirrors are just plain good. Design, development, and engineering all take place in-house, and the company even holds a few patents for some of its innovations. They have their own laboratory for product testing, to ensure that every mirror that wears the Kemimoto name is tough enough to go the distance. The mirrors are designed for beginners and professionals alike, with ridiculously simple install procedures that typically require a hand tool or two and just a few minutes of your time to set up. They are made to suit the overall aesthetics and performance requirements of the vehicles they are designed for.
      As an example, let’s take a look at a pair of Kemimoto’s lighted side mirrors designed for Sport Side-by-Sides. As the name implies, Kemimoto has built two levels of lighting into each of the side mirrors. You can fire up one or both of the lights in each mirror. And with an angle of illumination of 195 degrees, you can see exactly where you are going.
      Additionally, these mirrors boast shatterproof tempered glass, which helps protect the driver and passengers in case of an impact. They also feature a breakaway design, so they will fold up if you get a little too close to a tree or any other obstacle rather than snap right off. When it comes to construction, Kemimoto made the shell out of a high-quality ABS, while and the frame and bracket are built out of aluminum.
      Of course, Kemimoto is more than just mirrors. The brand also produces and sells its own saddlebags for motorcycles, seat bags for ATVs, backpacks, roll cage cargo organizers, and other storage accessories. They also manufacture high-quality whip lights and mounts, UTV cupholders, dome lights, windshields, vehicle covers, and even some riding gear. But high-quality, fairly priced ORV mirrors will always be the company’s specialty.
    • Dream Car Giveaway
    • By Rich1028
      Pine Ridge ATV Trails 10-4-22
      Upper Peninsula of Michigan
  • Gallery Images
