For 2018, Arctic Cat has it's line up includes the ALTERRA branded ATV which is kind of short for "All-Terrain" and makes good use of the shortened word with some of the features these ATVs are now coming with. Whether you are using it to hunt, ride in mud, ride on the trails, use it for work, or just play around, Arctic Cat has an ALTERRA ATV for you.
The ALTERRA comes in 90, 150, 300, 500, and 700 models with 2 versions in the 700 series with the ALTERRA TBX 700 leading the group of ALTERRA ATVS with:
  • 695cc Single-Cylinder Closed-Loop EFI Engine
  • 300-lb Capacity Rear Cargo Box
  • Electronic Power Steering
  • 10-Inch Suspension Travel
  • 11-Inch Ground Clearance
You should also check out the ALTERRA MUDPRO 700 LTD Built with a 695cc EFI engine, ruthless suspension and a competitive streak, engineered for riders who like to get dirty and won’t settle for second place!
Check out the models below:
Alterra MudPro 700 LTD
SINGLE-RIDER
$9,999USD
Alterra VLX 700
SINGLE-RIDER
ALTERRA VLX 700
$5,999USD
Alterra VLX 700 EPS
SINGLE-RIDER
ALTERRA VLX 700 EPS
$6,999USD
Alterra TBX 700
SINGLE-RIDER
ALTERRA TBX 700
$9,799USD
Alterra 500
SINGLE-RIDER
ALTERRA 500
$4,999USD
Alterra 300
SINGLE-RIDER
ALTERRA 300
$3,999USD
Alterra 150
SINGLE-RIDER
ALTERRA 150
$3,499USD
Alterra DVX 90
SINGLE-RIDER
ALTERRA DVX 90
$2,999USD
Alterra 90
SINGLE-RIDER
ALTERRA 90
$2,999USD
Full line up of 2018 Arctic Cat ATVs can be seen at Textron OffRoad: https://www.textronoffroad.com/atv
  • 5 months later...
