Hello all , looking for folks preferred brand and wt of oils to use in the Engine , transmission , differentials , coolant and brakes ... Also 100% synthetic media filter for engine oil .
Any response is appreciated .
Sent from my SM-G930V using Tapatalk
Engine oil: 0W-40 Mobil 1 full syn engine oil
Transmission: 5W-30 Mobil 1 full syn (you can use many different things in the tranny, its just a some gears, chains, and bearings) chaincase oil, dex 3 or 6, GL5, or engine oil
Coolant: any conventional green coolant works mixed 50/50
Brakes: Dot 4 brake fluid, valvoline
Rear final drive: Valvoline GL5 75W-90 syn
Front final drive: if its a hillard drive (mostly 2004 and newer polaris models) then I use polaris demand drive, if it has hillards on the hubs (2004 and older polaris models) the I use GL5, some people use ATF type F or ATF dex6 but I find I do not use much of the fluid so I just buy the polaris stuff.
Thanks for the response Sir !
I'm open to other suggestions anyone has .
I'm partial to( Redline Oil) products ...anyone using Redline oil in there ATV's ?
Thanks for any response [emoji106]
    • By docdoug72
    • By RadRob
    • By Mhatayas
      What oil does everyone like to run in the older quads?
