2008 Polaris Sportsman 500 EFI HO, 4x4 won’t work in reverse
By
Enad Nessumsar, in Polaris ATV Forum
Similar Tagged Content
By Admin
Looking for Polaris ATV VIN (Vehicle Identification Number) Number Decoders? Once you find your ATV VIN number off the tag on your Polaris ATV, you can go to all kinds of websites that have VIN Decoders available. The best ones are backed by the Polaris ATV manufacturer, however there are plenty of aftermarket Polaris ATV VIN Decoder websites on the web. This topic will stay pinned and if you find any to add, please do it with a reply.
The following Polaris ATV VIN Decoder websites are available where you can just enter your VIN number and it will shows you some of your ATV model details:
CARFAX https://www.carfax.com
By oxidized_black
Victory VIN Decoder @ Motoverse.com
By jwline
Friday evening went riding, rode for a good hour or so everything was fine. I went to take a short ride to the restroom (less than 100 yds away) and all of the sudden everything flickered and then just died out. Accompanying the problem I noticed the killswitch completely locked up. Once daylight hit took the killswitch apart to find it had shorted out and melted the plastic inside. Has anyone else had anything similar to this and if so what did you do to fix the situation? I have a new killswitch on the way to replace the obvious problem but was wondering could there be a bigger issue at hand. We tested with a voltage meter to make sure everything was still getting power from the battery and as far as we could tell it was.
Any advice/info would be GREATLY appreciated.
Thanks.
By quadcrazy
View File 1985 - 1995 Polaris ATV Service Manual (All Models)
Covers the following models:
1985 Scrambler Trail Boss
1986 Scrambler
1986 Trail Boss
1986 Scrambler
1986 Trail Boss
1987 Trail Boss
1987 Cyclone
1987 Trail Boss 4x4
1987 Trail Boss 4x4
1987 Trail Boss 4x4
1988 Trail Boss 2x4
1988 Trail Boss 4x4
1988 Trail Boss 250 RIES
1989 Trail Boss
1989 Trail Boss 2x4
1989 Trail Boss 4x4
1989 Big Boss 4x6
1989 Big Boss 4x6
1990 Trail Blazer
1990 Trail Boss 250
1990 Trail Boss 2x4
1990 Trail Boss 2x4 350L
1990 Trail Boss 4x4
1990 Trail Boss 4x4 350L
1990 Big Boss 4x6
1991 Trail Blazer
1991 Trail Boss 250
1991 Trail Boss 2x4
1991 Trail Boss 2x4 350L
1991 Trail Boss 4x4
1991 Trail Boss 4x4 350L
1991 Big Boss 4x6
1991 Big Boss 6x6
1992 Trail Blazer
1992 Trail Boss 250
1992 Trail Boss 2x4
1992 Trail Boss 2x4 350L
1992 Trail Boss 4x4
1992 Trail Boss 4x4 350L
1992 Big Boss 4x6
1992 Big Boss 6x6
1993 2502x4
1993 3502x4
1993 2504x4
1993 3504x4
1993 Sportsman
1993 2506x6
1993 3506x6
1993 Trail Boss
1993 Trail Blazer
1994 3002x4
1994 4002x4
1994 3004x4
1994 4004x4
1994 3006x6
1994 4006x6
1994 Trail Boss 2W
1994 Trail Blazer 2W
1994 Sportsman 4x4
1994 Sport
1995 3002x4
1995 4002x4
1995 3004x4
1995 Xplorer4x4
1995 4006x6
1995 Trail Boss
1995 Trail Blazer
1995 Sportsman 4x4
1995 Scrambler
1995 Magnum 2x4
1995 Magnum 4x4
1995 Sport
By quadcrazy
1986 Scrambler
1986 Trail Boss
1986 Scrambler
1986 Trail Boss
1987 Trail Boss
1987 Cyclone
1987 Trail Boss 4x4
1987 Trail Boss 4x4
1987 Trail Boss 4x4
1988 Trail Boss 2x4
1988 Trail Boss 4x4
1989 Trail Boss
1989 Trail Boss 2x4
1989 Trail Boss 4x4
1989 Big Boss 4x6
1989 Big Boss 4x6
1990 Trail Blazer
1990 Trail Boss 250
1990 Trail Boss 2x4
1990 Trail Boss 4x4
1990 Big Boss 4x6
1991 Trail Blazer
1991 Trail Boss 250
1991 Trail Boss 2x4
1991 Trail Boss 4x4
1991 Big Boss 4x6
1991 Big Boss 6x6
1992 Trail Blazer
1992 Trail Boss 250
1992 Trail Boss 2x4
1992 Trail Boss 4x4
1992 Big Boss 4x6
1992 Big Boss 6x6
1993 2502x4
1993 3502x4
1993 2504x4
1993 3504x4
1993 Sportsman
1993 2506x6
1993 3506x6
1993 Trail Boss
1993 Trail Blazer
1994 3002x4
1994 4002x4
1994 3004x4
1994 4004x4
1994 3006x6
1994 4006x6
1994 Trail Boss 2W
1994 Sportsman 4x4
1994 Sport
1995 3002x4
1995 4002x4
1995 3004x4
1995 Xplorer4x4
1995 4006x6
1995 Trail Boss
1995 Trail Blazer
1995 Sportsman 4x4
1995 Scrambler
1995 Magnum 2x4
1995 Magnum 4x4
1995 Sport
Similar Topics
By Richard Western
Hi guys,
I am hoping someone might be able to help me out. My Kawasaki 300 4x4 has an issue where it doesn't seem to want to go into neutral and also it will shift into reverse without using the lockout knob.
If anyone can suggest what to look at it would be very much appreciated.
Thanks.
By Hodadical
I've inherited a 1995 Lakota 300... it has the knob in the center of the handbar to twist to go into reverse, but I've notice when downshifting, you don't have to have the knob turned, it will shift right past neutral and into reverse which is a little dicey if not all the way stopped. I followed the linkage back and twisting the knob seems to actuate the lever on the outside of the trans, the internals just don't seem to care about this.
What is the likely problem and how back is it to get to? I've never been inside of one of these transmissions.
TIA,
-Rob
By ezduzit
New to me xpress i believe shuts down when put into reverse, but if i hold the override button it will remain running.
This is not normal operation based on my scramblers i've owned before. She also grinds when i attempt to select high gear and wont engage. lastly she runs great in low gear . I dont know how to fix this or where to begin my troubleshooting. 1994 polaris 300 2x4 thanks in advance for any suggestions/solutions
By PeteSaracen
Im fixing up a beartracker 250. Starts right up with screwdriver to both solenoid terminals and pull start. Doesnt start at all with electric start button. Neutral light and reverse light come on when the atv is running but when it is off and the key is turned to on position, no lights come on. When button is pressed to start, nothing happens. No click in solenoid, nothing. Not too experienced with the electrical components but I have tested a few things. The Front stop switch assembly cable was broken so I replaced that hoping it would fix my electrical problem to the key bevel but still nothing.
By Michael Thornton
Why does the 2001 grizzly not have com bearings or something to protect the head.
