Went to replace battery, then put the old one back on instead. Seeming as it didn't quite fit, I moved the battery on its side, and moved the wiring around a bit. Screwed connectors down into the terminal, now it won't start. battery has charge, lights work,  but I hear clicking coming from the electric start, and the pull start will not work either. Could it be a bad wire or a wire that shorted??? it just worked right before I went to replace the battery
Make sure all your connections are tight and have the battery tested. Clicking like that at the starter sounds like its not getting enough juice. However, you could have a bad starter. I would jump the battery or make sure its fully charged.
* Topic moved to Yamaha forum
  • 3 months later...
    • By Rockbottom
      What should i test next?
      thanks ahead
    • By Mister907
    • By LMI
    • By Brent Wright
