Suzuki lt50 genuine or replica
By docdoug72
Has anyone had a suzuki 230 quad lock the engine up? Its a well maintained bike, it locked up when my son was riding it. Pulled the plug, it has connected with the piston. I'm thinking the con rod let go. I don't have a service manual. Does the engine need to come out to check further?
By Mhatayas
By mmikesell
First post here need some help/advice. I bought a 2001 king quad 300, vin number JSAAK43A212111871. I have been trying to do some basic maintenance as it runs but doesn't idle all that well . I want to take out and clean/repair the carb but when looking for parts it ask for model X Y K1 K2. How do I know which model I have? I have tried some vin decoders but they haven't told me. If anyone could recommend a carb rebuild kit for my quad Id appreciate it. Also any tips on tracking down an owners manual?
By opnea
Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
By hfrost112
i have a 1987 lt 230e with no spark anyone know if theres any aftermarket or cheaper solutions for a cdi
