So everything back together, no left over bolts/nuts or screws WTF! Any way determined the rear brake was sticking causing life to be a drag🙄 a real bear removing the drum as it must have rusted /welded itself on, had to use a puller to remove. Guess it was that run through the lower flooded pasture last yr and not pulling it off then and cleaning, won't make that mistake again brake cam lobe had so much corrosion it wouldn't budge, hence the shoes won't retract. Oh well, what else to do in spare time, LOL. Maybe now I can go mow my 4' tall grass/weeds. I have a spare ignition if someone needs it.
  • Ajmboy changed the title to 1998 Suzuki King Quad brakes
    • By vaneleus
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
    • By Olchap
      Thank you,
      Olchap
    • By RussB
      Has anyone found a rebuild kit or an aftermarket replacement for the original which costs 500.00 US dollars?
    • By Rickm59
      I have a 2022 Kymco MXU150 and have been trying to bleed the rear brakes for several days. I have used a vacuum and also tried the lever pumping. i took the caliper off and compressed the piston with a C clamp and had a tight brake lever. I put it back together and still cannot build any pressure in the brake system. Any ideas from anyone?  Thank you
