I got an ATV from a guy that ran out of time rebuilding an eiger 400. He put a nerma Piston and rings in. I finished it up and it smoked like a train. I took the head off and honed the walls and it looked like the rings where on the walls, but it smokes just as much. I'm confused what's wrong with this thing.
  • Ajmboy changed the title to Suzuki Eiger ATV smoking after new rings
What year is the suzuki eiger? Are you using the correct oil? From how you describe it, it sounds like oil is getting into the combustion chamber. How's the air filter look, is it oil soaked?
* Added ATV info to topic title and moved to Suzuki forum.
its a 2007 with like 4k miles. I did not have the filter on when testing it.
some smoking is normal for a break-in period but if you are getting excessive smoke it could be the wrong size piston/ rings setup, were the rings in the correct order? were the ring breaks alternated on the piston? hope this helps!
I didn't replace the Piston and rings so I'm not sure the sepcs or anything. I got new rings just to make sure there right and I'm replacing the valve seals also. I also got up sized rings if I need them.
39 minutes ago, mark7170 said:
Any updates on the smoke issue?  I'm about ready to go after a similar problem.
I ended up just buying a new jug and piston set and it fixed all my problems. If it's not smoking to bad and you haven't let the engine run for to long I'd let it run for a while first.
Nice
    • By Fonne
      Hi
    • By toe420
      I got a couple yamaha moto 4 225cc quads. The guy gave me several old starters with them. I see kits are available to rebuild them but does anyone have tips or tricks for doing it? I haven't rebuild a starter before so im not sure what to look out for.
    • By Arizona
      Just recently bought a dead 06 Eiger, Can someone post or send me a wiring diagram for it:?
      Need to check all wires, no power in most places, Cant seem to read the ones from online manual,
      too blury and cant tell wire color. Just too small. Thanks Az
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By Atomusthenes
