Suzuki Eiger ATV smoking after new rings
I got an ATV from a guy that ran out of time rebuilding an eiger 400. He put a nerma Piston and rings in. I finished it up and it smoked like a train. I took the head off and honed the walls and it looked like the rings where on the walls, but it smokes just as much. I'm confused what's wrong with this thing.
  • Ajmboy changed the title to Suzuki Eiger ATV smoking after new rings
2 minutes ago, Ajmboy said:
What year is the suzuki eiger? Are you using the correct oil? From how you describe it, it sounds like oil is getting into the combustion chamber. How's the air filter look, is it oil soaked?
* Added ATV info to topic title and moved to Suzuki forum.
its a 2007 with like 4k miles. I did not have the filter on when testing it.
7 minutes ago, steve shugart said:
some smoking is normal for a break-in period but if you are getting excessive smoke it could be the wrong size piston/ rings setup, were the rings in the correct order? were the ring breaks alternated on the piston? hope this helps!
I didn't replace the Piston and rings so I'm not sure the sepcs or anything. I got new rings just to make sure there right and I'm replacing the valve seals also. I also got up sized rings if I need them.
39 minutes ago, mark7170 said:
Any updates on the smoke issue?  I'm about ready to go after a similar problem.
I ended up just buying a new jug and piston set and it fixed all my problems. If it's not smoking to bad and you haven't let the engine run for to long I'd let it run for a while first.
      CARFAX https://www.carfax.com
    • By jashadams
      Hey all back again with my 1989 moto 4 250.
      After putting a new carb on it it's really sputtery, it has new gas and I'm wondering what to tune on the carb to make it idle better. I've attached a video to describe the issue more. The bike is still work in progress but I think the video gets the point across. Thanks!
      Snapchat-1142015191.mp4
    • By Lance Workman
      Kawasaki Prairie 700 is the machine. It’s starts and runs but has a miss. After running it til it’s warm, it’s start smoking like your spraying for mosquitoes. Has oil in the breather also. Checked compressions and getting low 40psi both holes. I know this has a decompression lobe. Any other ideas? Leak down check? I’m guessing it pretty much has to be rings. With it blowing oil back into the breather. Normal typical sign I suppose?
    • By oxidized_black
      Victory VIN Decoder @ Motoverse.com
