just bought a 2005 kazuma dingo 150cc and need help figuring out how to properly connect new wiring harness. and proper hook up of vacum lines? any help would be greatly appreciated
  • Ajmboy changed the title to 2005 kazuma dingo 150 wiring and vacuum lines
Let me know if you have any luck. I just joined cause I got a 2004 Kazuma 150cc as part of payment for some work. Its partially dismantled.motors complete. I need to know how run the complete wire harness cause it had been removed to paint.
    • By Arizona
    • By Peisledder
      Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
    • By davefrombc
      I added a pdf of  the wiring of the various connectors used in vehicle socket  and trailer plug wiring to the  "Other ATV files"  section in downloads.
    • By carkivey3
