how do i change my name from trx500r to tecate/250r RiDeR??
thanks
You cannot change your user name. You would need to register a new account with that user name, send a support request to delete your current one ,with the e-mail you registered with, to [email protected]
  • Admin locked this topic
    • By middlebrookgt
    • By C2INS
      How to Change the Oil on a Polaris ATV | Expert Village Videos
    • By Slitzer
      How often do you change oil in front/rear diffrentials and gearbox?
      If you own an all-terrain vehicle (ATV), regular maintenance is essential for optimal performance and longevity. One critical maintenance task is changing the ATV oil. This article aims to provide you with a step-by-step guide on how to change ATV oil, ensuring that your vehicle continues to operate smoothly. Let's dive in!
      Step 1: Gather the necessary tools and materials Before beginning the oil change process, make sure you have the following tools and materials at hand:
      New oil (check your ATV's manual for the recommended type and quantity) Oil filter (consult the manual for the correct filter size and type) Drain pan Wrench or socket set Clean rags or towels Funnel Safety goggles and gloves Step 2: Locate the drain plug and oil filter Park your ATV on a level surface and let the engine cool down to prevent any burns. The drain plug is usually located on the underside of the engine, while the oil filter can be found nearby. Refer to your ATV's manual if you have trouble locating these components.
      Step 3: Prepare for oil drainage Position the drain pan beneath the drain plug to catch the old oil. Using the appropriate wrench or socket set, carefully loosen the drain plug but keep it in place. Ensure that the drain pan is placed to catch the oil effectively.
      Step 4: Drain the old oil With the drain pan securely in place, remove the drain plug completely, allowing the old oil to flow out. Let the oil drain fully into the pan until it slows to a trickle. Ensure that you collect all the oil in the drain pan, as it can be recycled at an appropriate facility. Wipe away any excess oil around the drain plug and reinstall it securely.
      Step 5: Change the oil filter Locate the oil filter and use an oil filter wrench or your hands to loosen and remove it. Be cautious as the filter may still contain some oil. Once the filter is removed, inspect the mounting surface for any debris or leftover gasket material. Clean the surface thoroughly and apply a light coat of fresh oil to the rubber gasket on the new oil filter. Install the new filter by hand, tightening it according to the manufacturer's instructions.
      Step 6: Add new oil Using a funnel, pour the recommended amount and type of new oil into the oil fill port. Refer to your ATV's manual for the correct oil capacity. Take your time and avoid overfilling. It's advisable to pour in smaller increments, periodically checking the oil level with the dipstick until it reaches the appropriate level.
      Step 7: Check for leaks and clean up Once you've added the new oil, inspect the drain plug and oil filter for any signs of leaks. Tighten them if necessary. Wipe away any spilled oil and ensure that the oil fill cap is securely tightened.
      Performing regular oil changes on your ATV is crucial to maintain its performance and extend its lifespan. By following these step-by-step instructions, you can confidently change the oil in your ATV, promoting smooth operation and ensuring optimal performance on your next off-road adventure. Remember to consult your ATV's manual for specific instructions and recommendations.
