1987 Suzuki 250 lt 4wd fuel pump location
By hurnyak
What is the best way to remove the carb on a 2000 quadmaster 500? Does the gas tank need to come off first?
By Coyote251
I am hooking up a speaker on the rear of bike and want to use a factory auxiliary switched plug and not have to cut into the factory wiring or add another switch. I have read a bunch of posts that say there should be an auxiliary 12V connector in the front and one in the rear. I found the one in the front when I hooked up my winch but cannot find any in the rear. I have seen some pictures showing one on the right side attached to the down tube behind the side cover, but there is nothing on my 2024. Can anyone confirm that there is a auxiliary 12V connector in the rear on the 2024 700 Xmr? If so, can you please tell me where it is (with a picture if possible)?
By dkgg5755
By Louznmemind
(Question is at the end if you want to skip my blabbering) I got this unbelievably well taken care of Grizzly 350 in for a carb clean, it belongs to an elderly couple that bought it brand new in '07. Apparently whoever has been doing their oil changes for them never checked the air filter..
Obviously it got debris in the carb, it would still run but only idle with slight choke. I've taken it apart and cleaned it, have new o rings, gaskets, etc. As far as the mixture screw is concerned, I'm assuming I obviously need to remove the plug. I'm mainly a lawn equipment guy, I've worked on slide carbs in the past but never an unmolested one with the plug still intact. I hate to mess with it as the carb had very little debris but I'm sure the o ring needs to be replaced at minimum. Finally, the question: what's the best way of removing the plug? I DO NOT want to mess up this carb..
By ResQ91
Hi Guys!
Or ??
Dave
