So need some recommended maintenance I should do with my 1998 Foreman 450ES.  I didn't get much info as to what had been done so what's the things I should perform to start me from square one?  I'm not a mechanical genius but can do the basics.  I did adjust the toe today so I'm not a nooby.
Edited by bcsman
  • 8 months later...
I would start by changing the oil, grease all fittings including the steering connections, tie rods etc.   Then pull the differential fluids and change. They are often over looked.
Maybe a fresh spark plug.
Check the air pressure and you should be good to go.
I did all the above except greasing, there are no fittings on these older Hondas.  I was told to get a needle to put on my grease gun so I can inject grease into the ball joints, tie rods, and CV joints.
You can inject the grease but just put on a rubber glove and put it all around the fitting. I’m not so keen on making a hole in the rubber if it’s not needed.
Also don't forget the differential fluids.
How does it run and look ? Post a few pics. I’m a fan of the older bikes.
Create an account
Register a new account
Sign in
Sign In Now
    • By ruslan1o1
      Hey everyone looking for a suggestion of where i can start looking. But first I'd like to explain what happened. Took the bike this morning got it started in 6 degrees celsius in 6-7 kicks? No choke. Drove 6km and when shifted to next gear bike decided to just shut off, stopped checked everything out seemed good, started first kick and on i went, drove maybe another 2km bike did same thing but this time it took me 10-15 kicks to get it started, on the third time after a kilometer decided not to start at all. Kicked it like a 450 a couple hundred times, nothing. So far checked gas is good, bypassed fuel filter and on/off valve to eliminate that problem, hot wired the kill switch in case something got corroded there. Nothing. Any suggestions would be welcomed. (Heard valve adjustment are a must do?)
    • By Daleon
      I recently was gifted a 1998 Lakota 300 and it was modified to start only by electric start. ( Removed the pull start) So I put together all the parts he was able to find and I believe it's back together like it's supposed to be but when I start it via electric start, it turns over but I do not hear the sound a proper combustion sound makes. Furthermore, I did all the spark tests and it's showing none whatsoever.
       I installed a new starter and I believe I installed it correctly. Could I have accidentally thrown the timing off? I lined up the timing marks but the top mark will NOT line up correctly.
    • By Daleon
      Do not know what else I need to attach the pull start to this machine. I have the pulley but nothing to attach it with. Could you help with what else I need. It's a 1999 Lakota 300
    • By Michael76
      Just got a bayou 300 and put a new spark plug in it but it won't start.
    • By mattgoodwin
      I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
