Side by side
By Spritee1
not sure where to look next
By HSTAR
By ResQ91
Hi guys
battery and connections good
By Slitzer
Hi,
What I understand is correlation code for brakesensors, very little information in workshop manual.
By Johnfj44
The stock driver seat cushion is separated at a seam. I took the seat apart and found that the material has torn and cannot be re-stiched. I'm trying to find a replacement seat. Any suggestions? Hoping for a used seat but couldn't find one on Ebay.
