2000 Suzuki 500 Quadmaster Fuel Issue
By Joeguy
By Dsluder
By buriedpast
By Jdeaton011989
By HeWasRidinDirty
I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
