pics of my girlfreinds blaster, custom pink paint/seatcover, tag aluminum bars, fast trecker 18x11x8 rear tires on itp aluminum rims. Motor is bores .40 over with a wiscoe stock compresion piston, Vito's 3, stroker stuffer crank, new bearings, oil injsection removed (including gear for it) tors removed motion pro throttle cable installed. Runs with stock head pipe/silencer rejetted stock carb, stock airbox, makes for a wicked trail machine! tons of tourqe! kind weird for a blaster, oh yea dont forget the wicked pink/white flamed shock covers!:o
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By cruteg8
      Does anyone know forsure if u can swap out the Crank Case on a 2001 kawasaki Lakota 300 sport  with a kawasaki Bayou 300 Im seeing yes and no all over some say the mounting position is different so you can't swap the cases but everyother inernal engine part you can swap then im seeing no problem bolts right on can someone plz clarify who knows forsure
