What about the car driver? I bet his shorts are a bit squishy too....
Man...what a dolt.....biker rider....that is....
-TD
The first video that was posted with the motorcycle crash....Im talking about the comments under the video itself on break.com, not this thread ..........sorry for the confusion.
this is what someone posted......
"I say good for the car. : Anyone riding a motorcycle should be in a head on collision. That car needs a good washing now. It has blood all over it."
im just sayin that there is not need to say stuff like that.
Im not sure which Video you are talking about...However,,,,I did just Read them after you posted.....They didnt seem any more horrible than any other video I have seen....What Particular Comment are you talking about and why does it Bother you???
I see what you are saying now..
WoW the airplane video is pretty funny. I wonder if he pissed his pants on that one. It didn't seem to bother him that he kept passing out though. :bangheadc:
    • By crankin
    • By harryjr
      hello everybody my name is Harry jr and i recently picked up a 90's Yamaha moto4 225 i beleive and neede a starter was all he said ( i know right ) thats what they all say
      anyway i picked up a starter and installed it and when it is crankling it sounds as if it is not turning over freely as i9f there was a one way bearing not worrking correctly so pulled with recoil and it pulled back so hard i ripped out of my hand so hard it actually hurt now i have pulled and kicked a lot of bikes and such but never felt anything quite like this you can hear it try and fire and kick back but still acts as though somthing holding it back does that make any sense to anybody is it flywheel key , or valves wauyout any help would be great i picked tow of these up for $100 and tring to fix so we can ride as a family thank you in advance.
    • By onequad
      i got a 93 400 Kodiak the frame on one side is rusted out.  is this a comin thing? was wondering if it worth the  tumble to put in a used one. I'm worried most of the bolts will brake. it don't look the rusted over all. just the part were the frame boke in half. do all kodiaks have the same frame
    • By BenJammin
      I did a compression test on my 2005 Bombardier Traxter 650 CVT and it's 75 PSI.  service manual only talks about leak down test.  No specification for engine compression the manual.  What does 75 PSI tell me?  Thank in advance.
      A little history of this machine.  640 miles.  Picked it up about 2 years ago, not running. Probably the computer.  Tested all circuits and confirm it was the computer.  Long story short, I watched a Youtube video and fixed the computer. ATV now started and runs.  BUT, it tops out 20 MPH.  I cleaned the carb 3 times also using a Mikuni carb kit after the second time.  Slide in carb is going up and down.  Only adjustment for fuel is at 1.5 turns out.  NGK Sparkplug had soot on main part but brown on the electrode.  Champion sparkplug is brown.  I check CVT clutches and they both appear to engage like they suppose to.  Checked valve clearance it's 0.00, I can't get any feeler gauges in-between.  I check timing chain I believe it's in the correct position and hasn't skipped.  I removed muffler plug and drilled into muffler to try and make sure it wasn't plugged.
    • By joshua91673
      hi every one .anyone out there my issue is my kick start wont stay out  i have to have some one pull it out.  it pull out easy just wont stay out to kick it over .kicks over and starts no problem
      first post
      josh ohio
