  • Admin changed the title to 2006 Can-Am Outlander Max 400 Hard to Shift Gears
THIS IS QUITE COMMON OF CANAM ATVS. THE SHIFT ARM IS A 2 PIECE AND SOMETIMES LOOSENS AND GOES OUT OF ALIGNMENT TRY TO REALIGN AND LOCK TIGHT IT BACK TO POSITION. IF THAT IS NOT THE CASE ANT THE TOP HALF IS BENT YOU MAY NEED TO REPLACE
    • By canamKID
      20260711_150338.mp4
    • By mehim
    • By Coyote251
    • By ButchM
    • By dkgg5755
