Join Today, It's Simple and FREE!
Similar Topics
By Spartacus Stroppel
I dont like doing upholstery work.. but cant afford for someone else to do it for me so here's my go at it... picked up the staple gun at harbor freight 1/4" long staples... ordered the cover off of ebay.. the guys said to get this material as it is more forgiving... it's like a tweed nylon stuff... and not the fake leather stuff... here are the before... I did trim the old one so it wasn't rippling under the new one..but held the foam on the seat back..in pics is what was left of old one after I trimmed it...
Not to bad
By haulinbass02
I’m looking at breaking into the SxS scene and really want a 4 seater. BUT I also would like one that is 50” trail capable as well. I have small kids that need seats so we can all go play at one time. Looking around I’m just not seeing that there is one out there. Does anyone know if they do in-fact exist and maybe I’m just missing it?
Thanks for the help...
By BradF80
Anyone ever use a universal lawnmower seat to bolt onto the rear rack on an ATV for a passenger? I have an 2005 Bruin but I have yet to see a seat for it other than those uber expensive helmet box/seats.
Similar Tagged Content
By mothrottle
The VIN on my 2018 Kodiak 450 is not where it's supposed to be. I bought this used. Is there another "hidden" location where I can find it? Need the number for insurance co. Thanks in advance.
By Dimelol
I have a 2003 Kodiak 450 that i purchased a while back with around 300 hours on it. It has never ran right from the beginning. Initially i thought it was just a carburetor issue because it was all clogged up from sitting for months. It has been cleaned, rebuilt, and taken off probably about 10 times troubleshooting this problem. I have quadruple checked everything including float height ect and it is set correctly, the jets are also brand new, needle and seat have been pressure tested as well. So after all of that I am convinced that the carburetor is not the culprit. I have an issue where the idle is very choppy, almost as if it is misfiring with a rich condition on top of that. I can use a brand new plug and run the machine for just a few minutes and it will be a dry and and coated in black carbon build up. The exhaust also has a strong smell at idle. I had trouble restarting it when hot for a while, but i adjusted the valves and it seemed to solve that issue. They were both way out of tolerance (tight). The weird thing is, outside of idle it seems to run pretty well.
So with all that being said I have ruled out the carb/valves/compression and moved on to the ignition and this is where i have a few questions about factory specifications. I guess the main question I have is, how strict are these tolerances? And could them being off by this amount cause the issue I am having? Do all three of these parts really need to be replaced? I would like to know before I spend the money on these new parts, and it not fix my problem. Below I will list what the specs were in the service manual along with the reading i got. This is my first experience testing ignition components. I just found it odd that all 3 are out of spec according to the service manual.
Spark plug cap resistance: 10 kΩ at 20 °C (68 °F)
My Reading: 8.90 kΩ
Primary coil resistance: 0.18 ~ 0.28 Ω at 20 °C (68 °F)
My Reading: Fluctuated between 0.4 - 0.5 Ω
Secondary coil resistance: 6.32 ~ 9.48 kΩ at 20 °C (68 °F)
Reading was within the specified range.
Pickup coil resistance: 459 ~ 561 Ω at 20 °C (68 °F)
Reading was within specified range.
Rotor rotation direction sensing coil resistance: 0.085 ~ 0.105 Ω at 20 °C (68 °F)
My reading was 0.3 Ω
