I'm buying some mudlites tomorrow I can get 25 XL for 550 with type 5 rims shipped or should I go ahead and get the 26 XL for 50 bucks more. I been comparing weights and the 26 XL dont seem to be that much heavier than the 25 XL These are the weights I found from two different websites. These are going on a 06 Yamaha Wolverine 450 4X4
25x8-12 XL F/R 24
25x10-12 XL F/R 29
25x12-12 XL F/R 26
26x9-12 XL F 22
26x10-12 XL F/R 23
26x12-12 XL R 27
XL 25x8-12 19.5
XL 25x10-12 22.5
XL 26x9-12 23.2
XL 26x10-12 22.9
XL 26x12-12 25.9
u also have to pay attention to stress on the engine and tranny cause the bigger the tires the more the engine has to work. wat terrain do u drive one (rocky, muddy,sand). Finally if you get the 26's would you have enough space between the plastic and tire?
is a clutch kit hard to install?
Never put one in myself, but have riden belt drives that have a clutch kit. Have been told if you can change a belt , you can put a clutch kit on. It makes one heck of a difference in how they perform.
is it expensive? and wat does it do?
I don't know the cost. It changes the shift points basically. Makes a belt drive engage sooner and work/ perform better. Gorrilla axles has the best clutch kit, highlifter has a good one to.
I dont understand why i would need a clutch kit with the 25's since the kodiaks came with 25's stock unless they put a lighter clutch in the Wolfy
yes the 25 XL has the same lug as the 26 XL 1 1/8 The 25 AT has the 3/4 lug
I dont understand why i would need a clutch kit with the 25's since the kodiaks came with 25's stock unless the put a lighter clutch in the Wolfy
The chasis is the same, but the fine tuning is different than the Kodiaks . Sorry , just trying to save you some money down the road. Being a single range not a hi/low range tranny a clutch kit saves wear and tear on the belt. Just telling you what most mud boggers do.Same thing for the Scrambler owners to. Not to mention you won't notice as much of a power loss with a clutch kit going to bigger tires.
Ok thats what I wasnt sure of it yamaha tuned it different for the 23 inch tires Looks like i'll go with the 25's for now and then the clutch
Watch how hard you play in the mud until you get a clutch kit. We have a yamaha dealer that installs clutch kits for free if you buy tires and rims from them , wether a new quad or used. They swear by them.
now you know whatwould add to the performance and the look of this quad.
as soon as i seen the pic i thought.
that exhaust stands out. looks a little crappy. [no offense] :cute:
now picture an HMF sport series slip on.
Polished Aluminum with a Blue Turndown cap. and painted the back rack Black.
Now that would look.
BAAAADDDDDDD :yes:
I did paint the front bumper black along with the rear axle and differental. I was thinking about painting the rack black but as much as I use it I dont think the paint would last long. Maybe I should rhino coat it. After I get new black plastic the the whole thing will be done in black. I agree a pipe is one of the next things to get. Do they come in black?
they usually come in a lot of colors but not for that machine.
only brushed and polished aluminum
but they make color tips.
i would say polished alumunum and a blue turndown tip.
that would look soooo good on there..
it is somewhere around 270$ i think.
not bad at all. :yes:
    • By Tuzz
    • By hardcastle
    • By p5200
      I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
    • By rgeiser
      just wondering if i pay the thirty dollars how soon will i be able to access the manuals?
