96 big bear 4x4 no neutral light
Josh Cornelius
Hey Josh. Welcome to Quadcrazy. There are a few different relays on that bike. One is dedicated just to the neutral operation that brings the light on.  Have you checked that relay? Also the relay brings in a few other relays as well so you have to make sure that all relays have a power supply 12v going in and a ground going in as well   Power to the relays allows them to close and complete ignition and starter circuits. So if your handy with a tester I can help you through it.
Also you said you tested the neutral safety switch? There is a wire on that switch. Take a look at the diagram it’s indicated as “Sb”. That wire essentially is grounded when the bike is in neutral bringing on the light. Put a jumper from ground to that wire and see if the light comes on. And then go to all the relays and see if you have a 12v feed and ground wire going into it.    Also have you tested the stator coil?
@Frank Angerano I'm assuming the neutral relay is Workin because I could hear it clicking when I touched the ground to the switch while in neutral.. I used a volt meter on both neutral grounds and both had a closed circuit while in neutral and broke it when shifting out of neutral.. I haven't tried a jumper wire yet, was tryin to get everything to work on it's on before I had to force it, but that's definitely a good idea.. one of the other relays is reverse and I'm assuming it works because it clicks when I shift to reverse and the reverse light comes on.. I replaced the ignition coil and stator tryin to see if I could get it to fire, but no luck without neutral light.. I also used my volt meter on the neutral grounds and they were both good grounds to the battery and motor.. and by testing the neutral switch I just read continuity from the switch to the end of the wire while circuit was opened and closed.. (no reading opened and got a reading when closed circuit).. I will try a jumper tomorrow and check the other relays and let you know what I find.. if you think of anything else to try feel free to add.. all help is greatly appreciated..
ok, update: tested all relays, all are working, used a jumper and bypassed the neutral switches and got the neutral light to come on but still no fire.. also found a blue and white wire coming from the headlight, start, run\off switch that apparently got really hot as most of the coating was burnt off of it but didn't burn any others.. according to the wire diagram that wire runs from the run\off switch and goes straight to the cdi and is basically a ground because it connects with a black wire while in the "run" position.. I'm guessing that may have fried the cdi but the black wire isn't burnt.. any ideas? could the cdi be ok? maybe I could just ground the blue wire coming from the cdi and see if it fires? thanks for all the help.. that diagram was extremely helpful @Frank Angerano.. appreciate that
Maybe that on/off switch is shorted?
So yes the cdi coul have  taken a hit if that wire is burnt up.   Most likely a momentary cross of the battery terminals or someone cranking the hell out of it while jumping it with a car.  One or the other.   It would suck if someone had put the battery wires on the wrong spot.  They may have changed the main fuse after there mistake so you may never know.
Have you tested the stator coil ? Ohm meter? Test?
I have not ohm tested it because I just replaced it yesterday.. do you think I should with it being new? also, how could I test if it's sending signal to the cdi? the cdi is getting a good ground to it but nothing is coming out so I figured if I could test to see if something was goin in the cdi then I figured that would narrow it down to the cdi.. my key switch is acting funny too, if I barely turn it towards off, it kicks out the relays before it's even off, and sometimes I have to play with it to get it to kick them on.. seems like the whole electrical has taken a hit from something.. might as well replace the key switch, cdi and whole harness, by then it should work.. lol
Lol, new everything !!!! yea something catastrophic has happened.   Hopefully it was limited with the damage.  I would def replace the ignition switch.   Unfortunately there is no way to test the cdi. And they can be costly. I would continue testing everything before you pick up a cdi as per the repair manual specifications and go from there.
I didn’t realize that you replaced the stator coil.
That ignition should be replaced to rule out the neutral light.  Or any other contacts inside the switch aren’t making proper contact.
Have you double checked that the neutral light bulb is good as well as testing of your wires leading to the bulb ?
yeah, they on up there.. I have 200 in the bike and a hot shot cdi is 195.. lol.. key switch is only 9 bucks tho and a full harness is 100.. so even if I replaced it all 500 bucks ain't bad at all.. but yeah, so far I replaced stator, ignition coil, carb and intake.. yeah, the neutral bulb was bad so I swapped it with the reverse bulb temporarily because it was working and it still never came on until I bypassed the neutral switches.. so I'm assuming one of them is bad also.. but jumped, the light does come on now..
Ok, how close to the switch are you jumping it out? Reason I’m asking is maybe the wire is broken inside some place ? May not be seen to the naked eye because the conductor is broken inside and the outer vinyl jacket is fine?  ESP if there were burnt wires. And if your jumping it right at the switch then the switch def has something going on. You may get a closed circuit when you test it but it may be a poor connection.
I’m not sure how that switch works I am   going to look into it out of curiosity.
I just replaced  one on a Kawasaki where the switch itself was not bad but the part that touches the switch was.  The spring loaded contact that touches the contacts on the neutral safety switch  is what was causing the problem.  It was on the engine and part of the shifter mechanism.   But still no spark which leaves me to believe the cdi May be your problem is something was burnt up like you said. So that may solve the spark problem. But that neutral safety switch seems to have a problem.
I jumped it at the end of the wire where it plugs into the switch, so it's definitely the switch.. well there are 2, one on top of the motor and one on the bottom by the shifter.. the top one triggers the relay so I believe it's good, but the bottom one does not trigger the relay and I didn't test it, but I'm pretty positive it's the neutral light culprit.. and I recon I'm gonna spring for the cdi and key switch and see where that puts me.. plus at least at that point I'll know they are new..
wsu's? and will do.. after this one, I have another bike I bought that's supposedly out of time.. but the big question is why.. also, with the other bike, I don't know what it is or the year model.. that's another problem.. no stickers and it had a like a paint stamp serial number and that thing is long gone.. I do know it's either a Timberwolve or a wolverine 250 4x4.. I'll post pics of it too and see if anyone can guess what it is.. lol.. I got it and the big bear together for 200 bucks.. so even if they needed new engines they were worth it.. but both are complete bikes and all plastic is in good shape so I couldn't pass em up..
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By newguy024
    • By mga
    • By HSTAR
