Polaris 1996-1998 ATV Light Utility Service Manual
By jen
Wow...I packed a small soft side cooler with an ice pack at -4 F and inserted my Type K thermocouple sensor inside so I could monitor the temperature without opening. After 3 hours the inside temperature was 60 F...OMG! The ice pack was solid frozen. Standard temperature for safe storage is < 40 F. What I found by asking was that there should be no air space in the cooler. Packed with Ice preferably ice from connivence store (normally 0 F of less). Food should take up short day trip1:1 ratio.
Good coolers are expensive.
By cavry
O3 sat a while. Engine is running fine. I got it into neutral, did some general tune-up and cleaning then pulled the shifter pedal up and it locked up and will not release into neutral again. Does anyone have experience with this problem? Thanks for looking and any help.
Cavry
By Mreoiwerk
Hey, I'm thinking of upgrading my stock sport glide seat with memory foam as a bit of a project. I've seen how some guys use the heavy-duty padding inside the water repellent UTV seat cover fit Polaris Ranger XP 1000 crew for their UTV projects and wanted to try something similar for my bike.
Has anyone done a DIY foam upgrade and have any tips? What sort of foam density would people recommend, and how easy is it to remove and refit the factory seat cover over the new padding? Any advice gratefully received!
By OldATVowner
By mikeexplorer
