Rpackin2
2000 Xplorer 250 gas tank pick up screens
Does anyone know where to get replacement pickup screens go inside gas tank? Mine are rusted pretty bad where they plug into the threaded connector,, thanks
Share this post
Link to post
if it was rusted, you might want to remove your gas tank and clean it out with fresh gas and check your carb to make sure it doesnt have crap in the bowl
Share this post
Link to post
  • Similar Topics
    • By Wayne Carson
      Has anyone found a good replacement for the stock cooling fan? Mine is going out and OEM parts are outrageous. Polaris sportsman HO XP 850
    • By Karen
      Yamaha BRUIN 350 Quad
      Hi, think water got into the tank, have managed to drain fuel (not the best experience) and empty the carb of fuel ........ so it starts now and runs however, it cuts out on fuel and won’t restart, it will restart on reserve ?  When I turn it off and back onto fuel, it will start again.  If I take for a short run on fuel it will cut out again and only restart on reserve 😳. Any ideas what else I can check.  Many thanks
    • By JacobSlabach
      First of all sorry I have been MIA here for a while, been busy with school and work.  I'll try and reply on some other threads asap, but posting this one because I just picked up a 2017 sportsman 570 before the new year and popped a boot on it going through a mud hole.  The former owner had aftermarket axles on it to accommodate the 4in lift and idk what brand they are but they're skinny as heck and idk what boot to buy to rebuild with?  It's the rear right lower boot (under the brake calp.).  I'll post some pics when I can and sorry again I've missed yall on the forum!
    • By IAShooters
      I have a 2006 Bombardier Outlander 400  that I purchased new.  I use the Outlander for hunting and working around the acreage. Muffler has worn out with holes in it and I am looking for a replacement.  From what I can find, factory mufflers are no longer available.  Are there any after market mufflers that can be found that fit without having to hire an expert welder to get creative?   Not looking for high performance, just a good quiet muffler. thanks
    • By Nick Brooks
      Working on a 2002 Quest 500 and the grommets in the tank are rock hard and leak.  Any tips on replacing without having to pull the tank, hands are too big to get to the bottom gromment which is the worst one.
  • Similar Tagged Content
    • By Jeff Cotter
      I recently purchased a 2000 polaris xplorer 400 4x4.  When I bought it the starter was bad, speedometer didn't work,  and it had been sitting for 5 years. I replaced the battery, and starter. Changed all fluids, and got it running correctly.  Then replaced the speedometer in an attempt to make sure the awd would be available when needed.  And took it out for a couple hour ride with a buddy.
      It ran great that ride with no serious problems just a little carb issues which I was able to take care of on the trails.  Then a couple days later I decided to take it out for a ride by myself,  again ran great no issues other than a couple times it seemed to cough and then take off again.  That day when I was loading it I noticed coolant dripping onto the trailer and the overflow bottle was empty.
      Got home and decided to drain the counter balancer, when I did that I got about 3 cups of coolant. Im guessing that it needs new seals and all for the water pump.
      My question is how difficult is it to do the water pump and should I attempt it or should I send it down the road to the polaris dealership to get it done?
    • By Micah Gafford
      I've had a seriously annoying time trying to deal with the brakes on my rebuild. What size is the fitting that screws into the inverted flair cross and into the caliper? I plan on trying to make parts I need with braided steel hose.
    • By Kyle Meadows
      I am 17 and I don't have lots of money but I know my way around older 2 stroke dirtbikes but my grandpa gave me this four-wheeler and I have had nothing but issues with it. I went through gas tank/lines and the oil injection has been bypassed, I have mixed gas in the tank and it is for sure getting to the carb. I have cleaned the carb to the best of my ability. I can get it to try and start for a few seconds but won't run any longer than 5 seconds with or without ether. Please help
    • By Micah Gafford
      I'm Micah I live in southern Indiana in the Hoosier national forest. Just picked up my first ATV for extra cheap and I've gotta get it up and running from sitting in a friend's shed for a few years. It's a '95 Polaris Xplorer 400. I've had a little bit of experience with simple ATV stuff from the cheap chinese atv my in-laws bought for our kids. I don't expect nearly as many headaches but would love suggestions on what things to go through before putting in a battery, gas, and oil and trying to fire it up.
      Thanks!
      1996-2003 Polaris Xplorer 500 Service Manual
