1988 suzuki quadrunner 250cc 2x4 (LT-F250) not starting
By marlon smith
By BillR94
Thank you for your time
Bill
By middlebrookgt
By 97kingquad
By sunn
Have a high heat issue on the right side panel on my 2021 cforce 400, as complained about by the wife.
My heat gun shows after 15 minute ride in ambient 91 deg temps; 690 degrees on front end of muffler close to entry pipe and 375 on exit side of muffler. The right side plastic (where wife's leg would touch) was showing 175 degrees. This is rediculous!.
As I understand the muffler has a built in catalytic converter which obviously kicks off high heat particularly at front end of muffler, but the heat is atrocious.
What is everyone doing about this problem? Is there a replacement muffler to eliminate this issue?
