Came all the way from Pittsburgh pa to sell it. We was needed the cash to catch up on bills. When we got to the location in a shopping center by a giant eagle he was there he help my husband take it off the truck . When it came down to handing cash over he did but it was fake. My husband tried to stop him from taken off but it was too late no one freaking help they just watch not one single person did a thing. N the cops they r limited cause they can’t case which is bull sh** ; please if anyone seen our quad please let me know
The post Stolen 06 Honda trx450r appeared first on Stolen 911.
View the full article
    • By Coyote251
      I am hooking up a speaker on the rear of bike and want to use a factory auxiliary switched plug and not have to cut into the factory wiring or add another switch. I have read a bunch of posts that say there should be an auxiliary 12V connector in the front and one in the rear. I found the one in the front when I hooked up my winch but cannot find any in the rear. I have seen some pictures showing one on the right side attached to the down tube behind the side cover, but there is nothing on my 2024. Can anyone confirm that there is a auxiliary 12V connector in the rear on the 2024 700 Xmr? If so, can you please tell me where it is (with a picture if possible)?
    • By Martin82
      Hello to all,
      Im looking for a main wire harness for Polaris sawtooth 200,
      Thanks for info
    • By BillR94
    • By fixitforfree
      I have a 94 Trail Boss 250 2wd that will not go into forward. Reverse works great but forward just clicks but won’t engage. I’ve verified the shift lever is pushing far enough so I believe I have either an engagement “dog” or mating forward gear that are likely bad. I also see a fair amount of metal on the dipstick magnet. But if I ride the machine in reverse the gearbox seems quiet with no other issues by what I hear. That said I’m in process of pulling the gearbox to see what parts I need. The gearbox has 1341124 as the model number as shown in the photo below but I can’t find any gearbox on eBay or the Polaris parts site that matches that number. Is this 94 model a year that used some special gearbox? My tag on the box even looks different than all the tags on gearboxes I see for sale on eBay. I really want to buy new parts for the ones damaged in my gearbox to fix the one I have but just doing research at this point to see what gearbox I have to know which parts I need. Anyone with experience with this I welcome some advice or direction from what you have learned. Just FYI this machine is new to me but cranks, runs and idles perfect. It’s not beat up and will be a gem when I get this tranny fixed. Thanks.
