Well. From your pics. It looks like the p/o removed the entire front half of the 4wd. To start, I would buy the front axles, differential, & the drive shaft that connects to the trans. Would you happen to know if the 4wd engages
The axles ant other parts will run you probably another $300-$400 or so and miscellaneous nuts bolts and gaskets a few more bucks. Keep in mind this  all depends one the existing transmission working properly? Why was it disconnected in the first place? These are the things you have to look into.
Double check that all the tires are the same size as well. 4x4 vehicles have to have the same size tires all the way around  so they all rotate the same. It’s possible that after the 4x4 was removed the front tires were downsized ?
    • By HHurks
      Thank you!
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By tflack500tbx
      Background,
      Any Ideas?
    • By USRaider
      Hello all!
      Kept indoors but hasn't been run in 5 years.  We're not trying the engine until the gas is replaced, and the tires are reinflated. But the previous owner said their only issue was stalling when shifting to reverse without giving some throttle.
      I'm optimistic!  See y'all around!
    • By kevinohio
