Pressure testing a Polaris 250 trailblazer with motion pro tester. Atv leaks down from 6 psi to  3 and hold there and I can’t kind a leak with water and dawn soap. . New to pressure testing a atv but have done 100s of saws etc. was going to order clutch puller and flywheel puller andCheck seals. Also notice that there is a clutch alignment tool, do I need this if i pull clutch?
  • Ajmboy changed the title to Pressure Testing a Polaris 250 Trailblazer
You don't need a clutch alignment tool if you pull the clutch off. Just torque it to 40 ftlbs when you're putting it back on.
How much pressure should it hold for how long?
    • By LashinWheeler
      Any help would be great,
      Thanks!
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
