The play on my KQ 300 (1998) choke doesn't allow for the full movement downward on the thumb lever. So it goes about halfway down and if I push a little too far the cable pops out of the plastic setting it sits inside of. Then of course I have to take the control unit apart and put it back into position.
Is it normal for the thumb lever to not go all the way down?
I have no play left in the adjustment screw on the cable in the correct direction. The only play I have left would make it worse.
It'a a new-to-me quad so I'm not sure if it's a replacement cable or OEM.
It's a cable issue. It stretched. I'd replace it with oem but aftermarket sometimes works. While your at it. Replace the choke guide as well. Might as well do it since you'll be in there
    • By sandman001
      This 2006 ArticCat dvx400 didn't have a reverse cable. I got one and am wondering how it routes? If someone has a dvx400, could post a pic of there reverse cable routing, it would be greatly appreciated. Thanks
    • By Damien911
      Setting the timing on a 2005 Yamaha 250 Bruin
    • By Jason39
      I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
    • By GERONAMO308
      Hi all, does anyone know what type of plastic is used for making ATV fairings.
      In particular Suzuki Quadrunner 1992, if i cannot get a plastic for it in Red for the rear i will attempt repair.
      I have a King Chrome plastic welding kit, however you need to know what type of plastic you are welding.
      Any advice would be greatly appreciated.
    • By Randel1
