I have some wobble in my right rear wheel. Too much wobble.
So I've torn into it and will need two bearings and two (different) seals. I'd like to get them locally if possible but need to know the number on the sides of the bearings and seals as I don't know that my bearing shop can source them by vehicle model. I'm told they're very common bearings.
Any idea what the numbers are if mine end up being illegible?
Thanks,
Warren
Go onto motorsports.com or bike bandit. They have reference numbers for each bearing.
Or take them out and bring them with you.
    • By LCP92
    • By cruteg8
      Does anyone know forsure if u can swap out the Crank Case on a 2001 kawasaki Lakota 300 sport  with a kawasaki Bayou 300 Im seeing yes and no all over some say the mounting position is different so you can't swap the cases but everyother inernal engine part you can swap then im seeing no problem bolts right on can someone plz clarify who knows forsure
    • By BillR94
      Thank you for your time
      Bill
    • By Olchap
      Hi, I am new to  this forum and I am happy to be here.  I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is.  I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing.  I checked up near the radiator and found nothing.  Where else should I look?  See image below.
