1999 TRX300 Starting issue
KJINTF
Been slow in starting up, in the recent past it would start up in <1/2 second of the button press with a snap. Now it takes several seconds of cranking to get going. Once going runs as it always did. Replaced the plug no change. battery is good.
Before I tear it apart and look things over was hoping others might have had the same experience and have a quick fix for me
Thanks in advance for any and all suggestions to get this old machine starting quickly again as it has for 20 years.
Probably needs a valve adjustment would be my guess.   You can check this by taking a simple compression test. I would also check the fuel delivery system. Maybe a little bit of dirt caught up in the needle where the float is. This could cause The gas from getting up into the intake port of the carb.
You could have gotten some bad or dirty gas.
Hows the gas in the bike fresh ? Is the tank clean and maybe a fuel filter if you clean the carburetor.
Last thing is make sure there are no leaks on the intake boot where the carburetor is mounted and make sure your vent hose on the gas cap is clear.
Might be a valve adjustment - don't believe its ever been done - Will try a compression and leak down test this afternoon
Always used fresh gas with NO alcohol - only thing is that it's 91 only way to get no alcohol around these parts
Will also take a close look at the carb
Anyone know what the KV of the spark should be?  I have a Pico Scope with the pressure transducer for so can easily see the compression, spark amplitude, dwell, etc..
Strange this starting issue happened almost overnight about a week ago - Guess it's time to get my hands dirty
My guess would be a fuel delivery issue that can be solved with a good carburetor cleaning and add a fuel filter as well.   But I’m sure a valve adjustment is long overdue.
As far as spark goes if you can clearly see a good spark when you pull the plug and test it then you don’t usually need to dig deeper into that.
Might as well double check your timing as well while your adjusting the valves.
Our 1990 Fourtrax 300 starts instantly in less than a full crank. But our 1985 250 cranked on and on but it would start quicker if we shook the machine. It ended up being a plugged screen in the sediment bowl on the bottom of the fuel shutoff valve. It wasn't getting a good fuel flow to the carburetor.
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By mga
    • By Slitzer
      How often do you change oil in front/rear diffrentials and gearbox?
