Just share a light bar deal here 60% off
By gt_jacket
Hi,
I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in. Neutral and Reverse lights work.
All gears shift fine with no issues, has anyone seen this before? Just wondering if it is a bad sensor or something needs adjusting.
By Tuzz
By Brian Emerson
Hi Guys, this Quadmaster has an extremely loud bang after turning key off (from idle), scares the stock, dog and missus, any ideas on what to check.
Thanks and regards,
Brian
By Am2007
Hi everyone,
owner manual
service manual
engine manual
